ESRI.ArcGIS.DataManagementTools Send your comments to: Site Administrator | Terms of Use | PRIVACY | Copyright @ ESRI | Careers
num_of_scales Property
ESRI.ArcGIS.DataManagementTools Namespace > GenerateMapServerCache Class : num_of_scales Property
The number of scale levels to use when caching the source map document.
(In, Required)
Syntax
Visual Basic (Declaration)
Public Property num_of_scales As Integer
Visual Basic (Usage) Copy Code
Dim instance As GenerateMapServerCache
Dim value As Integer
instance.num_of_scales = value
value = instance.num_of_scales
C#
public int num_of_scales {get; set;}
Requirements
Target Platforms: Windows XP Professional, Windows Server 2003 family
