ESRI.ArcGIS.DataManagementTools Send your comments to: Site Administrator | Terms of Use | PRIVACY | Copyright @ ESRI | Careers
built_with Property
ESRI.ArcGIS.DataManagementTools Namespace > GenerateMapServerCache Class : built_with Property
This parameter allows you to select where the processing for the cache creation takes place. This Computer—to build the cache using the resources of this computer. ArcGIS Server—to leverage the resources of a specified ArcGIS Server to build the cache rapidly.
(In, Required)
Syntax
Visual Basic (Declaration)
Public Property built_with As String
Visual Basic (Usage) Copy Code
Dim instance As GenerateMapServerCache
Dim value As String
instance.built_with = value
value = instance.built_with
C#
public string built_with {get; set;}
Requirements
Target Platforms: Windows XP Professional, Windows Server 2003 family
