ESRI.ArcGIS.DataManagementTools Send your comments to: Site Administrator | Terms of Use | PRIVACY | Copyright @ ESRI | Careers
DefineProjection Class
See Also  Members
ESRI.ArcGIS.DataManagementTools Namespace : DefineProjection Class
Records the coordinate system information for the specified input dataset or feature class including any associated projection parameters, datum and spheroid. It creates or modifies the feature class's projection parameters. This tool supports coordinate transformation using either of two projection systems. It can be used to define a feature class as a spherical coordinate system with angular units (such as Geographic) or a planar coordinate system with linear units. Most geoprocessing tools assume you have a planar, two-dimensional feature class. So if your feature class is in a geographic coordinate system in Decimal Degrees (DD, angular units), use the Project tool to project your feature class to any suitable projected coordinate system in linear units (meters or feet).
Syntax
Visual Basic (Declaration)
Public Class DefineProjection
   Implements IGPProcess
Visual Basic (Usage) Copy Code
Dim instance As DefineProjection
C#
public class DefineProjection : IGPProcess
Inheritance Hierarchy
System.Object
   ESRI.ArcGIS.DataManagementTools.DefineProjection
Requirements
Target Platforms:Windows XP Professional, Windows Server 2003 family
