ESRI.ArcGIS.DataManagementTools Send your comments to: Site Administrator | Terms of Use | PRIVACY | Copyright @ ESRI | Careers
CalculateDefaultClusterTolerance Class
See Also  Members
ESRI.ArcGIS.DataManagementTools Namespace : CalculateDefaultClusterTolerance Class
This tool is intended for use with ArcGIS 9.1, or earlier. Calculates a default cluster tolerance value. The default cluster tolerance is the smallest cluster tolerance possible for a dataset and is calculated based on the dataset's precision and extent.
Syntax
Visual Basic (Declaration)
Public Class CalculateDefaultClusterTolerance
   Implements IGPProcess
Visual Basic (Usage) Copy Code
Dim instance As CalculateDefaultClusterTolerance
C#
public class CalculateDefaultClusterTolerance : IGPProcess
Inheritance Hierarchy
System.Object
   ESRI.ArcGIS.DataManagementTools.CalculateDefaultClusterTolerance
Requirements
Target Platforms:Windows XP Professional, Windows Server 2003 family
