ESRI.ArcGIS.ADF.Web.UI.WebControls
MapToolItem Class
See Also  Members
ESRI.ArcGIS.ADF.Web.UI.WebControls Namespace : MapToolItem Class
MapToolItem provides a means for interacting with the Map control on the client-side using built-in JavaScript and then doing something on the server-side based on the client interaction.
MapToolItem holds information about a Map Tool that is necessary for the control to setup the client tool action when it renders itself and to call the server tool action on postback.
Object Model
Syntax
Visual Basic (Declaration)
Public Class MapToolItem
Visual Basic (Usage) Copy Code
Dim instance As MapToolItem
C#
public class MapToolItem
Inheritance Hierarchy
System.Object
   ESRI.ArcGIS.ADF.Web.UI.WebControls.MapToolItem
Requirements
Target Platforms:Windows XP Professional, Windows Server 2003 family
