ESRI.ArcGIS.ADF.Web.UI.WebControls
MapDisplayNode Class Members
See Also  Fields  Properties  Methods
ESRI.ArcGIS.ADF.Web.UI.WebControls Namespace : MapDisplayNode Class
The following tables list the members exposed by MapDisplayNode.
Public Constructors
  Name Description
Public Constructor MapDisplayNode Constructor Constructor
Top
Public Fields
  Name Description
Public Fieldstatic (Shared in Visual Basic) LINE_RESOURCE
Public Fieldstatic (Shared in Visual Basic) POINT_RESOURCE
Public Fieldstatic (Shared in Visual Basic) POLYGON_RESOURCE
Top
Public Properties
  Name Description
Public Property AllowTextWrap (Inherited from TreeViewPlusNode)
Public Property AlwaysShowExpandCollapseButton (Inherited from TreeViewPlusNode)
Public Property BackColor (Inherited from TreeViewPlusNode)
Public Property Checked (Inherited from TreeViewPlusNode)
Public Property ClickBehavior (Inherited from TreeViewPlusNode)
Public Property CustomLegendOnClick (Inherited from TreeViewPlusNode)
Public Property CustomOnClick (Inherited from TreeViewPlusNode)
Public Property Data (Inherited from TreeViewPlusNode)
Public Property Depth (Inherited from TreeViewPlusNode)
Public Property EndRecord (Inherited from TreeViewPlusNode)
Public Property Expanded (Inherited from TreeViewPlusNode)
Public Property FeatureType The feature type of the layer
Public Property HideNodeShowChildren (Inherited from TreeViewPlusNode)
Public Property LegendCollapsedImage (Inherited from TreeViewPlusNode)
Public Property LegendExpandedImage (Inherited from TreeViewPlusNode)
Public Property NodeID (Inherited from TreeViewPlusNode)
Public Property Nodes (Inherited from TreeViewPlusNode)
Public Property NumberOfPages (Inherited from TreeViewPlusNode)
Public Property Offset (Inherited from TreeViewPlusNode)
Public Property PageNumber (Inherited from TreeViewPlusNode)
Public Property PageSize (Inherited from TreeViewPlusNode)
Public Property PagingTextFormatString The format string that defines how paging text appears. The fields are page starting record, page ending record, total record count, current page number and, number of pages. (Inherited from TreeViewPlusNode)
Public Property Parent (Inherited from TreeViewPlusNode)
Public Property ShowCheckBox (Inherited from TreeViewPlusNode)
Public Property ShowClearButton (Inherited from TreeViewPlusNode)
Public Property ShowLegend
Public Property StartingPosition (Inherited from TreeViewPlusNode)
Public Property StartRecord (Inherited from TreeViewPlusNode)
Public Property Text (Inherited from TreeViewPlusNode)
Public Property TextCellAttributes (Inherited from TreeViewPlusNode)
Public Property TextCellStyleAttributes (Inherited from TreeViewPlusNode)
Public Property ToolTip (Inherited from TreeViewPlusNode)
Public Property TreeViewPlus (Inherited from TreeViewPlusNode)
Public Property Value (Inherited from TreeViewPlusNode)
Public Property ValuePath (Inherited from TreeViewPlusNode)
Top
Protected Properties
  Name Description
Protected Property ChildrenContainerID (Inherited from TreeViewPlusNode)
Protected Property HoverColor (Inherited from TreeViewPlusNode)
Protected Property SelectedColor (Inherited from TreeViewPlusNode)
Protected Property TextCellID (Inherited from TreeViewPlusNode)
Top
Public Methods
  Name Description
Public Method AddLegend
Public Method AreChildrenValid Method that should only be used when the TreeViewPlus container for the nodes is using RenderOnDemand. This function returns a value indicating if the child nodes have not been rendered or they have been invalidated since last render. (Inherited from TreeViewPlusNode)
Public Method Clone Overloaded.  (Inherited from TreeViewPlusNode)
Public Method DisplayOnMap Display result item on map
Public Method EnsureVisible (Inherited from TreeViewPlusNode)
Public Method GetResourceName
Public Method GetVisibility Whether the layer is visible
Public Method InvalidateChildNodes Method that should only be used when the TreeViewPlus container for the nodes is using RenderOnDemand. This function will invalidate the child nodes so that the next time that Render is called, this node will re-render the child nodes down to the client. (Inherited from TreeViewPlusNode)
Public Method Refresh (Inherited from TreeViewPlusNode)
Public Method Remove (Inherited from TreeViewPlusNode)
Public Method RemoveFromMap Remove result item from map
Public Method Render Renders the control to the specified HTML writer. (Inherited from TreeViewPlusNode)
Public Method SetVisibility Whether the layer is visible
Top
Protected Methods
  Name Description
Protected Method AddAttributesToRender Adds HTML attributes and styles that need to be rendered to the specified System.Web.UI.HtmlTextWriter. This method is used primarily by control developers. (Inherited from TreeViewPlusNode)
Protected Method anySiblingHasChildren (Inherited from TreeViewPlusNode)
Protected Method RenderBeginChildrenContainer (Inherited from TreeViewPlusNode)
Protected Method RenderBeginTag (Inherited from TreeViewPlusNode)
Protected Method RenderChildren (Inherited from TreeViewPlusNode)
Protected Method RenderEndChildrenContainer (Inherited from TreeViewPlusNode)
Protected Method RenderEndTag (Inherited from TreeViewPlusNode)
Protected Method RenderNode (Inherited from TreeViewPlusNode)
Protected Method RenderPaging (Inherited from TreeViewPlusNode)
Protected Method RenderPostTextCell (Inherited from TreeViewPlusNode)
Protected Method RenderPreTextCell (Inherited from TreeViewPlusNode)
Protected Method RenderTextCell (Inherited from TreeViewPlusNode)
Protected Method setParent (Inherited from TreeViewPlusNode)
Protected Method setTreeViewPlus (Inherited from TreeViewPlusNode)
Top
