ESRI.ArcGIS.ADF.Web.UI.WebControls
ScrollWheelZoom Property
ESRI.ArcGIS.ADF.Web.UI.WebControls Namespace > Map Class : ScrollWheelZoom Property
Whether the map can be zoomed using the mouse scroll wheel.
Syntax
Visual Basic (Declaration)
Public Property ScrollWheelZoom As Boolean
Visual Basic (Usage) Copy Code
Dim instance As Map
Dim value As Boolean
instance.ScrollWheelZoom = value
value = instance.ScrollWheelZoom
C#
public bool ScrollWheelZoom {get; set;}
Return Value
Boolean value indicating whether the mouse scroll wheel may be used for map zoom.
Remarks
When this property is true (the default), the browser user may zoom the map in or out by scrolling the mouse wheel (or equivalent mechanism). If your application needs to reserve scrolling for other purposes, or it otherwise interferes with user interaction, you may wish to set this property to false.
Each click of the scroll wheel causes the Map to retrieve map tile(s) at the next scale level.
Requirements
Target Platforms:Windows XP Professional, Windows Server 2003 family
