ESRI.ArcGIS.ADF.Web.UI.WebControls
MapResourceManager Property
ESRI.ArcGIS.ADF.Web.UI.WebControls Namespace > Map Class : MapResourceManager Property
The ID of the MapResourceManager whose resources will be displayed on the map.
Syntax
Visual Basic (Declaration)
Public Property MapResourceManager As String
Visual Basic (Usage) Copy Code
Dim instance As Map
Dim value As String
instance.MapResourceManager = value
value = instance.MapResourceManager
C#
public string MapResourceManager {get; set;}
Remarks
This property must be set to the ID of a MapResourceManager added to the page. If not set, then a runtime error will occur.
Requirements
Target Platforms:Windows XP Professional, Windows Server 2003 family
