| Class |
Description |
| ActivityIndicatorNode |
| BeginCreateWebPageLayoutEventArgs |
Arguments for the BeginCreateWebPageLayout event. |
| BuddyControl |
Information about a control associated with another. This class stores the name of the associated control and the control to which it is associated. |
| BuddyControlCollection |
A collection of buddy controls. |
| CallbackResult |
A Web ADF class for passing results of a client callback to the browser. |
| CallbackResultCollection |
A collection of CallbackResult objects. Used for returning information to the client from a callback. |
| CallbackUtility |
| CartoDisplay |
Base class for a control that displays cartographic information. |
| CharacterPicker |
| CircleEventArgs |
Event arguments for a circle ClientToolAction |
| ColorPicker |
The base class on which Web ADF controls are built. Supports the callback framework for controls. |
| Command |
A button on a toolbar that executes code without requiring client-side interaction with the buddy control's display. |
| CompositeControl |
| Constants |
The class supports the .NET ADF infrastructure and is not intended to be used directly from your code. |
| ContextMenu |
| ContextMenuDismissedEventArgs |
| ContextMenuItem |
| ContextMenuItemCollection |
| ContextMenuItemEventArgs |
| Converter |
| CopyrightText |
ArcGIS Server Application Developer Framework for .NET CopyrightText Class. This class provides the attributes necessary to render a copyright notice on the Map web control image. |
| DataFrameEventArgs |
Event arguments for a change in data frames. |
| DataNotAvailableDrawingUtility |
| DataSourceManager |
Summary description for DataSourceManager. |
| DisplayCharacter |
Represents a single character and font. |
| DropDownBox |
A drop down box on a tool bar. |
| DropDownBoxItemCollection |
A collection of ListItem objects. |
| ExtentEventArgs |
| FeatureNode |
| FloatingPanel |
A panel into which other controls and HTML content may be placed. The floating panel may be moved, resized, collapsed and closed by the user. |
| FloatingPanelContentsRenderedEventArgs |
Arguments attached to the event of rendering a FloatingPanel. |
| FloatingPanelTask |
| GeocodeResourceItem |
Representation of a Geocode Resource in a GeocodeResourceManager control. |
| GeocodeResourceManager |
Represents a collection of geocode resources. |
| GeoprocessingResourceItem |
Representation of a Geoprocessing Resource in a Geoprocessing Resource Manager control. |
| GeoprocessingResourceManager |
Manages geoprocessing resources in a Web ADF application. |
| GISResourceItem |
Representation of a GIS Resource in a Resource Manager control. |
| Generic GISResourceItemCollection |
A collection of GISResourceItem objects. |
| GISResourceItemDefinition |
Defines a GIS resource used in a resource manager. |
| GISResourceItemDependency |
| Generic GISResourceManager |
Abstract generic class with common functionality for resource managers for maps, geocoding, and geoprocessing. |
| GraphicsLayerNode |
Node that displays task result items on map as a Graphics Layer |
| HelpDialog |
Displays a help url in a floating panel |
| InteractiveImageToolbarItem |
Base class for command and tool, toolbar items that can display an image. |
| InteractiveToolbarItem |
Base class for tool bar items that allow interaction: command, tool, select |
| LevelMapping |
| LevelScheme |
| LineEventArgs |
Event arguments for a line ClientToolAction |
| Magnifier |
Web control that allows the user to magnify a portion of the Map. |
| Map |
Displays an interactive map. |
| MapDisplayNode |
Node that displays task result items on map |
| MapResourceItem |
Representation of a Map Resource in a Map Resource Manager control. |
| MapResourceManager |
Manages map resources in a Web ADF application. |
| MapResourceNode |
Node that displays task result items on map as a map resource |
| MapTips |
Displays map tips on a map control. |
| MapToolItem |
MapToolItem provides a means for interacting with the Map control on the client-side using built-in JavaScript and then doing something on the server-side based on the client interaction.
MapToolItem holds information about a Map Tool that is necessary for the control to setup the client tool action when it renders itself and to call the server tool action on postback. |
| MapToolItemCollection |
A collection of MapToolItem objects. |
| Navigation |
| OvalEventArgs |
Event arguments for an oval ClientToolAction |
| OverviewMap |
Display an overview map that shows the extent of the main map. |
| PageLayout |
Provides the display functionality of the layout view for a map document served using ArcGIS Server. |
| PageToolItem |
PageToolItem provides a means for interacting with the PageLayout control on the client-side using built-in JavaScript and then doing something on the server-side based on the client interaction.
PageToolItem holds information about a PageLayout Tool that is necessary for the control to setup the client tool action when it renders itself and to call the server tool action on postback. |
| PageToolItemCollection |
A collection of PageToolItem objects. |
| PointEventArgs |
Event arguments for a point ClientToolAction or a click. |
| PolygonEventArgs |
Event arguments for a polygon ClientToolAction |
| PolylineEventArgs |
Event arguments for a polyline ClientToolAction |
| RectangleEventArgs |
Event arguments for a rectangle ClientToolAction |
| ResizeEventArgs |
| ResourceInitEventArgs |
| ResourceItemAddedEventArgs |
| ResourceItemInsertedEventArgs |
| ResourceItemRemovedEventArgs |
| ResourceManager |
An abstract class used by GISResourceManager, which in turn is used to create resource managers for maps, geocoding, etc. |
| ResourceRefreshedEventArgs |
| RotationAngleEventArgs |
| RotationNotSupportedException |
| ScaleBar |
ScaleBar web control. |
| ScaleEventArgs |
| ScriptsRegisterer |
Registers client scripts to the page |
| Separator |
A separator is a line that separates items on a Toolbar. Used for organizing ToolbarItems into groups. |
| SessionNotAvailableException |
Exception thrown when Session is not available for an operation that requires it. |
| SimpleTaskResult |
Object that represents a very simple task result. |
| Space |
A Space is the empty space on a Toolbar in which you can place the Html controls or the web controls of your choice. |
| StateManager |
Manages state for web controls. Uses Session state if available, otherwise uses ViewState |
| Task |
| TaskManager |
| TaskResultNode |
| TaskResults |
| Tile |
| TileDirectAccessInfo |
| TilingScheme |
| Toc |
Table of Contents: Used for rendering the layer/swatch information of the data sources in a Map. |
| TocClickEventArgs |
Event arguments for the TocControl's OnClick event. |
| TocSelectEventArgs |
Event arguments for the TocControl's OnSelectedIndexChange event |
| Tool |
A Tool is a button on a toolbar which when clicked executes some client-side code to set the stage for interaction with the display. When the interaction with the display is finished, it executes some code on the server side. At any point, only one tool is selected in a toolbar. |
| Toolbar |
A Toolbar is a collection of Tools and Commands that work on a set of Map controls or a set of PageLayout controls. |
| ToolbarBase |
| ToolbarCommandClickEventArgs |
Arguments for the Toolbar's CommandClick event. |
| ToolbarDropDownBoxIndexChangeEventArgs |
Arguments for the Toolbar's SelectIndexChange event. |
| ToolbarItem |
An item on a Toolbar. This is the base class for Tool, Command, Space, and Separator. |
| ToolbarItemCollection |
A collection of ToolbarItem objects. |
| ToolEventArgs |
Base class for the event arguments of a control's ClientToolAction events. |
| TreeViewPlus |
| TreeViewPlusNode |
| TreeViewPlusNodeCollection |
| TreeViewPlusNodeEventArgs |
| TreeViewPlusNodePageChangedEventArgs |
| UrlDialog |
Displays a url in a floating panel |
| VectorEventArgs |
Base class for the event arguments for a polygon and polyline ClientToolAction. |
| WebConfigurationCompleteEventArgs |
| WebConfiguratorAttribute |
| WebControl |
| ZoomLevel |
A web control used for changing the zoom level of a buddied map control. |
